Netbrain
Go BackThe Net-BrainerNetBrain Product Visio 2016 Export
Reply
Old 02-01-2018, 03:11 AM
Netbrain-user-germany Netbrain-user-germany is offline
Default Visio 2016 Export
Hi,
when I try to export a map to Visio 2016 netbrain shows that a Visio file has been created. But I can't open it with Visio 2016.
Thanks
Old 02-02-2018, 02:17 AM
Wengong Sun Wengong Sun is offline
Default Re: Visio 2016 Export
We may need to get more info to understand the issue that you are having now.
1. Is the first time that you have this issue? And are there any other have the same issue in your orginization?
2. Are you using NetBrain in an English language OS? Not only the display language is English. Just check the follow settings.
3. Can you please send your visio map and the map in NetBrain for further analysis? Since it is a complex issue, can you please contact us at support@netbraintech.com?
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
