Netbrain
Go BackThe Net-BrainerNetBrain Product How to add the ACE to NetBrain workspace?
Reply
Old 02-01-2013, 03:09 AM
Alex001 Alex001 is offline
Question How to add the ACE to NetBrain workspace?
I am trying to discover several Cisco load balancers model ACE, from the discovery, it does discover them as CSS, but they are not added into workspace?
I am playing with OEv4.1M2d. Any help will be appreciated.
Old 02-01-2013, 03:38 AM
Gerry Gerry is offline
Administrator
Default Re: How to add the ACE to NetBrain workspace?
Alex,
Sorry for the confusion.
This is a known issue in your version. It will be fixed in the next release V5.0.
Please do the following to fix it:
1. Switch to Workspace tab, click Vendor model drop down menu to choose Device Driver option.
2. Double click the CSS entry to open the Device Driver Properties window, switch to Config File tab, check the Build configuration file by snmp option.
3. Rediscover the ACE devices to see if they can be added into workspace.
Old 02-04-2013, 08:29 PM
Quote:
Originally Posted by Gerry View Post
Alex,
Thanks, it works perfectly!
Alex
Old 02-05-2013, 05:00 AM
entr04y entr04y is offline
We have a mixed environment with some CSS devices that we are phasing out and ACE4710's. Setting the snmp only function doesn't seem to get any configs from the CSS other than interface names, and only seems to pull interface and IP from the ACE. There is no routing data or NAT data retrieved from either device, and the full configurations are not available on either device. Are there any workarounds for the current version? If not, do you have an ETA on version 5, and are these issues addressed in it?
Thanks!
Old 02-18-2013, 02:56 AM
Administrator
Sorry for the delay.
There are not workarounds for these two device types, also OE5.0 doesn't address these issues. :-(
Old 02-20-2013, 11:14 AM
When can we expect a fix? The ACE is a central part of our network and not having its configuration leaves a huge gap in the network architecture.
Old 02-22-2013, 08:40 AM
Administrator
Quote:
entr04y
Sorry for the inconvenience, I filed a case for req dept. considering this feature request.
Reply
Bookmarks
Tags
Operator Edition
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
