Netbrain
Go BackThe Net-BrainerNetBrain Product I failed to add some Palo Alto device to the workspace.
Reply
Old 12-14-2017, 11:51 PM
JohnSmith JohnSmith is offline
Post I failed to add some Palo Alto devices to the workspace.
Here is the log.
Ping [192.168.x.y] via Network Server(192.168.z.z); Successful
Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [SmithSNMP][version:v2c] to [192.168.x.y] via Network Server(192.168.z.z)
Send RO = [SmithSNMP][version:v1] to [192.168.x.y] via Network Server(192.168.z.z)
Send RO = [SmithSNMP2][version:v2c] to [192.168.x.y] via Network Server(192.168.z.z)
Send RO = [SmithSNMP2][version:v1] to [192.168.x.y] via Network Server(192.168.z.z)
SSH to [192.168.x.y] via Network Server(192.168.z.z)
Connected Failed: Code 30016, Description Invalid username or password reported by server, or bad private key.
SSH to [192.168.x.y] Disconnected
SSH to [192.168.x.y] successfully via Network Server(192.168.z.z)
Return from Device:[Smith-PA-FW(active)>]
Sending "set length 0" command
Received:Smith-PA-FW(active)>set
Smith-PA-FW(active)> set length
Smith-PA-FW(active)> set length 0
Invalid syntax.
Sending "exit" command
Any suggestiongs?
Old 12-15-2017, 11:38 PM
Edel Edel is offline
Default Re: I failed to add some Palo Alto device to the workspace.
Please try adding 192.168.x.y to Network definition table.
Under Workspace Menu, go to Vendor Model drop down menu>Network Definition, Click Add button to define Device Type and Driver.
Then please try rediscover your device.
Old 12-17-2017, 09:25 AM
Wink Re: I failed to add some Palo Alto device to the workspace.
It really worked! Thank you Edel!
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
