Netbrain
Go BackThe Net-BrainerNetBrain Product ssh key mismatch
Reply
Old 09-12-2017, 06:20 PM
dstoneham dstoneham is offline
Default ssh key mismatch
netbrain 6.2
windows server 2010
I'm getting ssh key mismatch errors when running qapps. I can't find where to manage the keys. Is there a way to manage ssh keys through netbrain or must it be done manually? If manually, where are the keys located?
Old 09-13-2017, 01:24 PM
wdstoneahm wdstoneahm is offline
Default Re: ssh key mismatch
I should clarify ssh is still using password authentication. I'm referring to managing the "known hosts" file that keeps records of the host and it's RSA public keys.
Old 09-14-2017, 11:02 PM
Administrator
The SSH credentials for the Device in NetBrain could be located and modified at the "Shared Device Setting" of each device. if the SSH credential is wrong or the privilege is not enough to execute some CLI commands, please modify the SSH credential at the shared device setting directly, and run Tune to verify.
BTW, the RSA token is not supported.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
