Netbrain
Go BackThe Net-BrainerNetBrain Product Netbrain AP Discovery
Reply
Old 04-22-2016, 05:39 PM
DJBORN DJBORN is offline
Default Netbrain AP Discovery
I have roughly 500 access points on 2 Cisco Wireless LAN Controllers. Netbrain is detecting the access points as a CISCO IOS Switch, without a sysObjectID. This is causing the APs to take up a network device license, I cant block them since it isn't detecting the sysObject ID properly. How can i fix this?
Netbrain can SSH to the APs fine, its just the SNMP setting that isn't configured right. I did notice when i do a "sh snmp" on the access point, it says "snmp agent not enabled."
Any help would be appreciated, it is a headache to have to delete the APs almost weekly. I know i could block the IP from being scanned, however they are all set DHCP.
Old 04-27-2016, 05:16 AM
Administrator
Default Re: Netbrain AP Discovery
Hi DJBORN, we create a case 43867 to track this issue and will get back to you via E-mail. Thanks!
Reply
Bookmarks
Tags
Network Discovery
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
