Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Why do I receive a /32 prefix route in EIGRP?
Reply
Old 06-17-2009, 12:57 AM
David.C David.C is offline
Default Why do I receive a /32 prefix route in EIGRP?
Hi, all
Why do we receive a /32 prefix with EIGRP ?
example :
Rack1SW1#sho ip route eigrp
129.1.0.0/16 is variably subnetted, 8 subnets, 3 masks
D 129.1.3.128/25 [90/2172672] via 129.1.17.1, 00:00:16, Vlan17
D 129.1.3.0/25 [90/2172672] via 129.1.17.1, 00:00:16, Vlan17
D 129.1.13.0/24 [90/2170112] via 129.1.17.1, 00:00:16, Vlan17
D 129.1.13.3/32 [90/2170112] via 129.1.17.1, 00:00:16, Vlan17
D 129.1.23.2/32 [90/2682112] via 129.1.17.1, 00:00:16, Vlan17
D 129.1.23.0/24 [90/2682112] via 129.1.17.1, 00:00:16, Vlan17
150.1.0.0/24 is subnetted, 4 subnets
D 150.1.3.0 [90/2298112] via 129.1.17.1, 00:00:17, Vlan17
D 150.1.2.0 [90/2810112] via 129.1.17.1, 00:00:17, Vlan17
D 150.1.1.0 [90/130816] via 129.1.17.1, 00:00:17, Vlan17
I mean why do we get the /32 routes and when ?
thanks
Old 06-17-2009, 01:34 AM
Chris Chris is offline
Default You have a /24 in there as well.
My guess would be PPP that happens to be exchanging a peer neighbor-route.
You have /32 AND /24 there.
Old 06-17-2009, 05:34 AM
Default thanks
thanks, Chris.
as a matter of fact i am running PPP but why do i advertise them in EIGRP ?
Old 06-17-2009, 05:35 AM
Default because
Because, most likely, in your EIGRP configuration you put the "network" command with the /24 mask which encompasses EVERY link within that range.
So, if you had:
10.1.12.0/24 as your subnet
10.1.12.1 on your router
10.1.12.2 on the other router
Your "show ip route connected" would look like:
C 10.1.12.0/24 Serial1/0
C 10.1.12.1/32 Serial1/0
If you put "network 10.1.12.0 0.0.0.255" under router eigrp, you'd get both.
If you put "network 10.1.12.1 0.0.0.0" under router eigrp, you'd only get the /24 network!
Reply
Bookmarks
Tags
CCNP
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
