Netbrain
Go BackThe Net-BrainerNetBrain Product copy tab from one map to another
Reply
Old 12-18-2017, 12:16 PM
ap1436 ap1436 is offline
Default copy tab from one map to another
If I have multiple map tabs on a two different maps is there a way to copy map from one tab to another?
Old 12-19-2017, 05:11 AM
Edel Edel is offline
Default Re: copy tab from one map to another
Hi ap1436,
This features cannot be implemented in NetBrain at present. I will file a feature request on your behalf to our Product Management team, they will evaluate the request and decide how to proceed. I will keep you posted on the progress.
You can copy and paste network objects between maps, including shapes and notes as a workaround.
1.Select one or multiple network objects in a Qmap. The objects can be network devices, links, LANs, shapes, notes, and other objects from a map.
2.Press the Ctrl + C keys to copy the selected object(s).
3.Press the Ctrl + V keys to paste the object(s) to another Qmap.
Note: It's not allowed to copy and paste the network objects (such as devices) in the same map, but you can copy and paste the shapes and notes in the same map.
Further operations:
▪To undo the modifications in a Qmap, press the Ctrl + Z keys or click the undo_icon icon on the quick access toolbar.
▪To redo your modifications in a Qmap, press the Ctrl + Y keys or click the redo_icon icon on the quick access toolbar.
Reply
Bookmarks
Tags
MAPs
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
