Netbrain
Go BackThe Net-BrainerNetBrain Product Is there a running time limit on Dashboard?
Reply
Old 02-02-2018, 04:53 AM
libingx006 libingx006 is offline
Default Is there a running time limit on Dashboard?
If I start to run a Dashboard and then close the webpage, is it still running on server side or just ended? And is there a time limit for Dashboard to run?
Old 02-02-2018, 04:58 AM
Administrator
Default Re: Is there a running time limit on Dashboard?
If you close the webpage of a running saved dashboard, it will continue to run in the back. There is no time limit for a Dashboard to run, it only stops when someone manually ends the task.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
