Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time EtherChannel to servers won't come up
Reply
Old 04-09-2010, 12:24 AM
ashley ashley is offline
Default EtherChannel to servers won't come up
Hi, all
I am creating etherchannels on a stacked 3750 -lacp but the channel wont come up. Is there something wrong w/ my config?
I've shut/no shut all interfaces too.
interface Port-channel10
switchport access vlan 14
switchport mode access
Current configuration : 144 bytes
interface GigabitEthernet1/0/43
channel-group 10 mode active
spanning-tree portfast
interface GigabitEthernet2/0/42
Old 04-09-2010, 01:13 AM
m.stone m.stone is offline
Default Re: EtherChannel to servers won't come up
check if interface port-channel is not created in shutdown
in order to have the bundle up when using LACP the other side must talk LACP otherwise after some time member links are removed from bundle if no LACP frames are received on them
so check if server or other switch is configured to use LACP
Old 04-11-2010, 09:04 PM
I bounced my port-channel10 and still nothing
So from my config its safe to assume the other end/servers. May be having issues?
I wonder why the interface is showing (I)
in summary
Old 04-12-2010, 09:15 PM
David.C David.C is offline
Could you pls try the configs with
port-channel 1
switchport mode trunk
interface f0/1
switch mode trunk
interf f0/2
switch mode trunk
Not sure if you wanted the Etherchannel in Bundled( P ), right now it is showing( I )because it is stand alone which is correct if you want in access mode.
Old 04-13-2010, 08:49 PM
Chris Chris is offline
Yes probably LACP daemons has not been started on server side.
You can check this on the log message of the switch you should see messages telling that no LACP message is seen on port.
I see this multiple times when server people asks us an LACP bundle so we usually configure our side after they do their part on server NICs
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
