Netbrain
Go BackThe Net-BrainerNetBrain Product Using Regex for hostname matching
Reply
Old 05-04-2010, 03:04 PM
Erick Erick is offline
Default Using Regex for hostname matching
Is there a way to match devices via standard perl regex?
ie. add all devices "(a|b)cd..e" to a device group "CD - Charlie Danial's site"
Old 05-05-2010, 02:28 AM
David.C David.C is offline
Default Re: Using Regex for hostname matching
Hi, Erick
NetBrain does not support filter devices using Perl regular expression. However, for NetBrain Workstation OE, you can match devices via searching configuration files.
1. Input a key string in the Search box, and check the Search Configuration Files option. You can input a prefix of IP addresses and hostnames, SNMP locations, or any other key commands configured on devices.
2. Click the Search button, the Search Result pane opens. All devices whose configuration files contain the input strings are listed.
Tips:
1. Press Ctrl or Shift key to select more devices.
2. Right-click the selected devices, you can:
Map the devices.
Remove the devices from workspace.
Add the devices to a device group.
Hope to help.
Old 05-27-2010, 12:25 PM
The lack of regex matching is really starting to become annoying. I guess I am too used to working with CLI and not GUIs *shrug*
Show me all devices at site "ab" == ls -la | egrep "^(r|s|w)ab"
Show me all of the primary WAN routers == ls -la | egrep "^r..wan10"
Show me all of the backup WAN routers == ls -la | egrep "^r..wan11"
And so on.
Old 05-27-2010, 10:07 PM
Yes, exactly. I think we will add the support of regular expression into our further route.
Old 06-01-2010, 09:59 AM
That would be awesome. Even simple things such as the start and end of line markers would be a good start
Old 06-03-2010, 09:26 AM
recoyle recoyle is offline
Agree, start and end of string would help. Throw in a wildcard option for single or multiple character and you have 90% of what is needed.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
