Netbrain
Go BackThe Net-BrainerNetBrain Product NAT Router
Reply
Old 06-08-2010, 12:17 PM
Erick Erick is offline
Default NAT Router
I have a router or three that the only method of access is via NAT. Trying to get this into NetBrain is not as straight forward as other devices. How do I model a device with an IP address which does not exist on the device?
Old 06-09-2010, 02:23 AM
David.C David.C is offline
Default Re: NAT Router
Quote:
Hi, Erick,
To access a device, you can manually edit the management IP address in Device Settings window.
1. Right-click a device and select Device Settings. The Device Settings window opens.
2. Click the Management IP field and enter a new one as desired.
3. Click the OK button.
Old 06-09-2010, 10:33 AM
I tried that yesterday and then did Check Device. NetBrain only polled the devices listed in the drop down menu for interface list.
I originally added this device by importing the configuration text file. Does this require me to remove the device and re-add in a different mannor?
Old 06-10-2010, 01:20 AM
Hi, Erick,
I tested it and it works. You can try this way:
Firstly, modify the management IP and click Apply, then OK.
Next, re-launch the Device Settings window and check the device again.
For any questions, please let me know.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
