Netbrain
Go BackThe Net-BrainerNetBrain Product Map Center Sync
Reply
Old 06-08-2010, 06:38 PM
recoyle recoyle is offline
Default Map Center Sync
Is there any way to get Map Center to Sync with the server and other users, as part of the "refresh workspace"?
Old 06-09-2010, 02:36 AM
David.C David.C is offline
Default Re: Map Center Sync
Hi, recoyle,
The Map Center works locally. I am afraid you cannot sync its data from Enterprise Server. However, you can map a local hard drive which stores the maps, then, other people can specify this drive and sync with it.
Hope to help.
Old 06-09-2010, 10:36 AM
Erick Erick is offline
I ran into the exact same thing, sharing static maps for others to be able to view. I ended up creating a share and storing maps there like David said. When doing this be careful because once or twice I did not make sure NetBrain was pointing to the share when saving and maps ended up on my local workstation instead of the server share.
Old 06-10-2010, 01:16 AM
Quote:
Yes, exactly. Erick did the smart way. Just as Erick said, do be careful not to overwrite the maps on server site.
Old 09-14-2010, 03:17 PM
Most of my support team that is using netbrain runs remotely over vpn. Microsoft mapped drives over VPN is at best flakey. Can we get an integrated mapcenter sync in netbrain? This would eliminate many problems we have to deal with related to mapped drives.
Old 09-14-2010, 03:58 PM
lgao lgao is offline
Rick-
Storing the Qmaps of certain map center folders into NetBrain server, and allowing users to use "refresh workspace" to sync up is likely in the next release's feature list. Please let us know if you have further requirements along this line...
Thanks
Lingping
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
