Netbrain
Go BackThe Net-BrainerNetBrain Product Nested service policies
Reply
Old 06-21-2010, 05:02 PM
Erick Erick is offline
Default Nested service policies
Usually NB does a good job showing everything related to an interface but I came across this one:
interface Vlan123
description bogus edited interfacs
bandwidth 43000
ip address 192.168.1.1 255.255.255.252
no ip proxy-arp
ip pim sparse-mode
ip route-cache flow
ip ospf authentication-key 7 123456789
load-interval 30
service-policy output Parent_policy
policy-map Parent_Policy
class class-default
shape average 43000000
service-policy Child_Policy
policy-map Child_Policy
class Voice
priority 4000
class Routing_Protocols
bandwidth 100
class Call_Signaling
bandwidth 100
class Network_Management
bandwidth 100
class MCAST
bandwidth 350
class Video_Services
bandwidth 100
estimate bandwidth drop-one-in 100 delay-one-in 50 milliseconds 250
NetBrain only shows the part in blue within the pop-up window. The additional, not everything, portion in red does not show. his child service policy and related ACLs do not show. Can y'all look into this one please?
thanks,
erick..
Old 06-22-2010, 02:31 AM
David.C David.C is offline
Default Re: Nested service policies
Hi, Erick.
The configuration tip windows uses Design Reader Filters to filter out the configuration files. When your mouse hovering an interface, it shows the basic interface configuration only.
To see the detailed QOS configuration, in this case, you should use Design Reader, and select the filter: Router > Quality of Service > Class-based WFQ.
Let me know if you still have problem on this.
Thanks.
David
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
