Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Disable default data view?
Reply
Old 03-27-2018, 06:42 PM
jimmytootshoes jimmytootshoes is offline
Default Disable default data view?
Is there a way to disable or override the default data view? By default it shows the interface ID and the IP address. For some maps I would like to not show any text at all, and just display the connection link.
Old 03-27-2018, 06:49 PM
Default Re: Disable default data view?
I found where to do this.
Open a map then click the Map link (upper right tool bar) > Map Settings, then disable "Interface Name"
Reply
Bookmarks
Tags
One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
