Netbrain
Go BackThe Net-BrainerNetBrain Product How to export the inventory report which contains the stacked switches
Reply
Old 09-29-2016, 01:59 AM
David David is offline
Default How to export the inventory report which contains the stacked switches
It appears that NetBrain ignores stacked chassis and includes them as part of the parent switch. This is causing our asset reports to not include switches that we know are installed. Is there some way to include them in reports or some means to enable showing them separately?
Old 09-29-2016, 05:02 AM
Administrator
Default Re: How to export the inventory report which contains the stacked switches
Hi David,
Please follow the instruction below to have a try.
1) Create an Asset report. Select all options below in the window.
device /site/module/module and interface information and interface summary/only export physical interface info
2) Then click the 'start' button. Once done, you open the report in the location.
There is a tab for the asset report to see the stackable switches.
Reply
Bookmarks
Tags
Operator Edition
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
