Netbrain
Go BackThe Net-BrainerNetBrain Product Why the configuration files are not up to date?
Reply
Old 06-15-2017, 08:26 PM
jamesyu jamesyu is offline
Default Why the configuration files are not up to date?
Why the device configuration has changed, NetBrain is not automatically synchronized configuration?
Old 06-15-2017, 08:42 PM
Administrator
Default Re: Why the configuration files are not up to date?
Quote:
Hi James,
Normally NetBrain synchronizes data from the device based on the daily/weekly benchmark (Depending on your settings
If you want to synchronize config immediately after the configuration of devices changes, we can issue a retrieve live data task with option "Auto Update Baseline Configuration "check box checked.
For the details, please refer to attached document.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
