Netbrain
Go BackThe Net-BrainerNetBrain Product How to check if Proxy server has access to devices?
Reply
Old 10-31-2017, 01:51 AM
Aubrey Aubrey is offline
Default How to check if Proxy server has access to devices?
I upgrade to 7.0, but fail to discover device, how to check if Proxy server has access to devices?
Old 10-31-2017, 01:54 AM
Sherry Sherry is offline
Default Re: How to check if Proxy server has access to devices?
Hi,
Please RDP to this Proxy server, follow the steps below to verify the SNMP access. Regarding the CLI access, please verify via login your device using putty.
1) Open the NetBrain SNMPWalkTool.exe (Please download it from: http://ws2.netbraintech.com/download/SNMPWalkTool.zip) on your Proxy Server, set Target IP address (One device at a time), SNMP credentials to retrieve the SNMP data. Please note that this could take some time. After the process is finished, the program will create a text file of the walk result. Please change the timeout to 60 seconds in the SNMPWalk Options.
2) Please enter the SNMP string and MIB variable: 1.3.6.1, and start the walk process. (It may take several minutes to retrieve the results).
3) Please check the result, if the result is empty, that means the server cannot get SNMP information from the devices.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
