Netbrain
Go BackThe Net-BrainerNetBrain Product Does netbrain support vrf-lite mapping or juniper netscreen subinterfaces
Reply
Old 01-07-2013, 09:14 AM
watcher60 watcher60 is offline
Default Does netbrain support vrf-lite mapping or juniper netscreen subinterfaces
Hi guys,
just getting started with the a demo of the netbrain enterprise. I have run it against our core 6500 VSS pair and noticed it does not seem to recognise any of the vrf-lite instances, or the sub-interfaces on our juniper netscreen isg-1000's firewalls.
Regarding the sub-interfaces, it does see the interfaces just does not appear to detect they are connected to the different VRF's on the 6500 VSS core.
Can anyone advise if they have netbrain working with vrf-lite?
thank in advance
Old 01-08-2013, 12:52 AM
Gerry Gerry is offline
Administrator
Default Re: Does netbrain support vrf-lite mapping or juniper netscreen subinterfaces
Hi,
NB is able to discover the VRF-lite instances and document the vss info. Can you try to right click the device then select Device Data>Route table to open the Live Route Table window, click the VRF drop down menu to see if it switches to different vrf$name? If not, click Retrieve Live to retieve live data to have a try. As for the sub-interfaces, can you send us a screenshot or qamp to support email support@netbraintech.com, we will analyse it then give it back to you.
Gerry
Reply
Bookmarks
Tags
Firewall, Network Discovery, Routing
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
