Netbrain
Go BackThe Net-BrainerNetBrain Product Failed to get Network card address... Trunked Interface
Reply
Old 07-19-2012, 12:41 PM
preston.hill preston.hill is offline
Default Failed to get Network card address... Trunked Interface
The network card on the server needed to access various segments of our network requires a trunked interface with specific routes.
It is running Broadcom BASP drivers - has internet access, and downloaded the demo directly, yet is unable to install with a "Failed to get network card address" message.
Is there anything that can be done or that supports an environment like ours?
thank you
Old 07-24-2012, 03:52 AM
Gerry Gerry is offline
Administrator
Default Re: Failed to get Network card address... Trunked Interface
thank you
Hi Preston,
We sent the solution to your email on 7-19-2012. Did it work for you?
Thanks
Gerry
Old 12-02-2013, 08:48 AM
Willy Daro Willy Daro is offline
Quote:
Originally Posted by Gerry View Post
Hi Preston,
Thanks
Gerry
Hi, this answer could be of interest for me also, could you post it on the forum ?
Rgds
Old 12-02-2013, 10:09 PM
Administrator
Hi Willy,
Here is the solution for "Failed to get network card address" problem.
Root Cause:
NetBrain cannot find your MAC address. - We bind our license to it. You might be using team NIC teaming in your environment.
Solution:
- Disable the team NIC and try to activate the license again.
Note:
- Our trial license does not support team NIC but our formal license does.
Old 06-18-2014, 05:44 AM
kim@dataequipment.no kim@dataequipment.no is offline
Hi,
Im trying to activate Our trial License on a VM from Hyper-V. I'm getting the same error: Failed to get network card Access.
Are Vm's on Hyper-V supported?
- Kim
Old 06-19-2014, 01:10 AM
Administrator
Quote:
Originally Posted by kim@dataequipment.no View Post
Hi,
- Kim
Hi Kim,
Hyper-V is supported.
I replied to you with the solution, we can use the case to track this issue.
Case#00009313
Thanks
Gerry
Old 07-11-2014, 07:30 AM
Spansgberg Spansgberg is offline
Quote:
Originally Posted by NetBrainTAC View Post
Hi Kim,
Case#00009313
Thanks
Gerry
How come you send these solutions directly to E-mail and don't post them on the board??
I also have the Failed to get network card address on a freshly installed Windows Server 2012 Hyper-V guest with one NIC, and with more that 10.000 views on this thread alone, I don't think I am the only one.
What is the solution to this?
Old 07-17-2014, 08:12 PM
TheMicster TheMicster is offline
I am having the same problem. I'm running windows 8.1 which is running hyper-v and has vm's running under it. What can I do to get this to activate?
Old 07-23-2014, 09:58 PM
Administrator
Hi Spansgberg,
Sorry for delay.
For the Hyper-V activation, we need to create formal license and use the email to perform the offline activation. So please send the request to support@netbraintech.com if you have the issue.
Old 07-23-2014, 10:02 PM
Administrator
Quote:
Hi TheMicster,
Please send the question to support@netbraintech.com, they will guide you the steps how to activate it offline. But, please note, the offline activation only works for NetBrain Enterprise Suite Advanced trial. Sorry for the inconvenience.
Thanks
Gerry
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
