Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time There is an error of Search: Failed to initiate Jscript engine when login NetBrain from workstation
Reply
Old 07-06-2017, 09:56 PM
libingx006 libingx006 is offline
Default There is an error of Search: Failed to initiate Jscript engine when login NetBrain from workstation
Error still there after login
Old 07-06-2017, 11:14 PM
Wengong Sun
Guest
Posts: n/a
Default Re: There is an error of Search: Failed to initiate Jscript engine when login NetBrain from workstation
The root cause of this error may be that your Jscript.dll may not be registered correctly. Could you please try the followings to see if this issue can be resolved or not?
1. Run command prompt as Administrator.
2. Change folder by issuing the following command :
For 64-bit:
cd C:\windows\SysWow64
Type the following command and hit Enter:
regsvr32.exe jscript.dll
3. Run the installer again to see if your NetBrain workstation works well or not. If not, please get us the latest support log for further analysis.
Reply
Bookmarks
Tags
One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
