Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Big Pathing Job
Reply
Old 03-05-2018, 02:35 PM
netbmed netbmed is offline
Default Big Pathing Job
So the internal network has perhaps 12 firewalls. What I'd like to know is whether there are any of these firewalls would block traffic from a particular device (a security scanner) to any section of the network. It there any way to do such a macro operation?
Old 03-05-2018, 10:05 PM
Jia.Xing Jia.Xing is offline
Default Re: Big Pathing Job
This is dependent on the complexity of the Access List/Policy.
1. If the Access List/Policy is able to be searched, in the bar on the top, you can search for the Access List/Policy using the security sanner's IP as criteria. Any Access List/Policy in all firewalls' configs that meet the criteria will be listed in the result.
2. If the Access List/Policy is too complex to be searched, you can run path calculation to check. Given the fact that you have a large scale of network, you can batch add path calculation tasks in the "Path" pane on the left. You can use "Export" to export a CSV file of the path calculation tasks, modify the CSV file to include all your target subnets and then import back.
Reply
Bookmarks
Tags
Firewall, Network Discovery, One-Skill, one-skill-at-a-time
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
