Netbrain
Go BackThe Net-BrainerNetBrain Product Multi-Vendor Support - what do you have in mind
Reply
Old 10-14-2010, 08:48 AM
lgao lgao is offline
Default Multi-Vendor Support - what do you have in mind
On July 2012, NetBrain will release a special multi-vendor edition of V4.1, which will allow users to add full support of a new vendor or model without waiting for a software release. The customization is also GUI driven with minimum amount of scripting.
The following is the vendor list supported by NetBrain out of box
Router:
Cisco IOS Router
Cisco IOS-XR Router
Juniper Router
Switch:
Cisco IOS Switch
Cisco Catalyst Switch
Cisco Nexus Switch
Juniper EX Switch
Brocade Switch(Foundry Series)
Arista Switch
Dell Force10 Switch
HP ProCurve Switch
Extreme Switch
3Com/H3C Switch
Firewall:
Cisco PIX/ASA Firewall
Juniper NetScreen/SSG Firewall
Checkpoint Firewall
Load Balancer:
Cisco CSS Load Balancer
F5 Load Balancer
Note: The level of support may vary slightly with different model.
Old 10-20-2010, 10:01 AM
recoyle recoyle is offline
Default Re: Multi-Vendor Support - what do you have in mind
Here are a couple of very popular devices not on your list and a suggestion to provide another "class of discovered devices" similar to the "SNMP discovered devices" it would be useful to have a "CDP discovered devices" that includes all devices found by CDP even if they are unreachable via SNMP or Telnet.
1. Cisco Wireless LAN Controller (WLC):
Current SNMP discovery just returns "Failed:SNMP++ Get Error, SNMP Variable does not exist(2)"
2. Cisco Light weight access point (LWAP):
This device does not support SNMP or Telnet but it does appear in CDP and is configured in the Cisco Wireless LAN Controller.
3. Any CDP discovered device.
There is a more general case of any device that is discovered via CDP but is not reachable via SNMP or Telnet.
Old 08-25-2011, 06:22 AM
savuka
Guest
Posts: n/a
Hi
Arista devices
7050
7100
7500
Kind Regards
James
Old 09-14-2011, 11:18 AM
Erick Erick is offline
I keep getting requests to show tunnels of the SilverPeak WAN accelerators. NetBrain discovers them and I can place them on maps which is nice. Having the ability to SNMP query the appliances and get the map of tunnels between appliances would be very helpful.
Old 09-14-2011, 11:19 AM
If you could expand support on the CSS models that would be awesome. Give the ability to show what end stations are connected to the VIPs on the CSS.
Old 05-04-2012, 11:45 PM
docwavers
Guest
Posts: n/a
I would like to see the following supported:
Arista
Packet Light ONS Switches
Cisco ONS Switches
Simena PFS (Now NetScout)
Thanks
Old 05-25-2012, 04:50 AM
Lasse Jensen Lasse Jensen is offline
Hi,
I would like to see Juniper SRX firewall in cluster setup and Juniper EX switches
Old 06-20-2012, 04:16 PM
Quote:
Originally Posted by savuka View Post
Hi
Arista devices
7050
7100
7500
Kind Regards
James
Arista is Now supported with V4.1m1
Old 07-05-2012, 11:06 AM
69444091 69444091 is offline
Quote:
Originally Posted by Lasse Jensen View Post
Hi,
Juniper EX switches is supported in OE4.1Ma now.
Old 07-12-2012, 05:59 AM
dmmg
Guest
Posts: n/a
Hi there,
I'd be nice to have the following supported:
Network:
- HP ProCurve
- HP H3C (Commware 3.x and 5.x)
- Enterasys
Security:
- Juniper SRX (JUNOS) with VSYS and VR.
- Fortinet with VDOM.
- Check Point VSX with VS and VR.
I know I'm being greedy...
Thanks
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
