Netbrain
Go BackThe Net-BrainerNetBrain Product Webservice for integration into other tools
Reply
Old 02-09-2016, 12:31 PM
dominique.vocat dominique.vocat is offline
Default Webservice for integration into other tools
Hi,
i would like to get data from Netbrain via a Webservice.
Stuff i would like to get is
- data like in the inventory report
- data like the netcool integration i.e. send source and dest ip and get a visualization OR tabular data
I would like to be able to integrate the rich data source into our problem analysis tools.
Old 02-14-2016, 08:35 PM
Administrator
Default Re: Webservice for integration into other tools
Hello,
NetBrain provides the command line interface to map the path between two points or map around a single device. Ticket systems such as Netcool and NetView can integrate with NetBrain via this command line interface. While the command line is invoked from an alert, the map will be created for this alert. With one click, a NetBrain map can be exported to a Visio or PNG file.
Here's the document about NetBrain Third Party Integration Details and it include Netcool in section 4
https://c.na2.content.force.com/servlet/servlet.FileDownload?file=00P4000000ZzmsW
Case# 15175
Old 03-29-2018, 06:31 AM
So, we have now Netbrain 7 and the REST api does not seem to provide any means to list all nodes - what am i doing wrong?
I aim to get a list of all known devices.
Old 04-15-2018, 10:51 PM
Administrator
Hi,
Yes, the REST api doesn't provide a list of all nodes.
Please try Inventory report>Device report. https://www.netbraintech.com/ftp/IE70b/OnlineHelp/index.html?inventory-report.htm
Old 04-17-2018, 01:58 PM
lheavrin lheavrin is offline
Quote:
Originally Posted by NetBrainTAC View Post
Hi,
I created a group and set a dynamic search that would always match our devices like "device name always includes hyphen". Then I just did an API call to list the devices in that group. It's not perfect but it does the job as long as you have a variable that will always match.
Old 06-06-2018, 08:30 AM
Declanw Declanw is offline
Question Re: Webservice for integration into other tools
Hi there,
The URL directs me to something called Salesforce. I'm not sure what that is.
Is there another link to the document?
Regards
Declan Watts
BT plc.
Hello,
Case# 15175
Old 06-07-2018, 02:31 AM
Administrator
Quote:
Originally Posted by Declanw View Post
Hi there,
Regards
Declan Watts
BT plc.
Hi Declan,
Please refer to the 7.0 NetBrain_API_and_System_Integration_Guide from this link: http://ws2.netbraintech.com/download/NetBrain_API_and_System_Integration_Guide.pdf
Thanks!
Old 11-21-2018, 01:10 PM
jrsikors jrsikors is offline
Hello -
Brand new to NetBrain and the API. I'm not sure if I missed something obvious, but I'm just trying to test out the basics.
https://www.netbraintech.com/ftp/IE70b/OnlineHelp/index.html?getallinterface.htm
So if I do:
https://myNBIP/ServicesAPI/API/CMDB/interface/getAllInterfaces/
I get a:
{"statusCode":790005,"statusDescription":"Inval id token."}
Great -- that error is expected -- I didn't put in a parameter.
If I do a
https://myNBIP/ServicesAPI/API/CMDB/interface/getAllInterfaces/MYSWITCH
I get a:
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Am I missing something obvious?
Thanks!
Jeff
Old 11-22-2018, 01:10 AM
Administrator
Hi Jeff,
Could you please try URL like below example with GET method instead of POST:
http://10.10.13.89/ServicesAPI/API/CMDB/interface/getAllInterfaces?hostname=BJ_Acc_SW1
Please note: BJ_Acc_SW1 is a device hostname
Hope this helps.
Thanks
Quote:
Originally Posted by jrsikors View Post
Hello -
So if I do:
I get a:
If I do a
I get a:
Thanks!
Jeff
Old 11-22-2018, 12:26 PM
Thanks for the assistance!
I'm getting a:
When I use that URL format:
<my server>/ServicesAPI/API/CMDB/interface/getAllInterfaces?hostname=<my switch>
I know the switch exists, I just did an export of the Inventory Report.
Thanks again!
Jeff
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
