Netbrain
Go BackThe Net-BrainerNetBrain Product NetBrain SOAP API web services
Reply
Old 04-09-2018, 03:51 AM
James.lin James.lin is offline
Default NetBrain SOAP API web services
Hi, Does CE version support NetBrain SOAP API web services? I have a CE 6.2 and refer online document to enable this function, but doesn't work.
The document say enabling this function need to edit Web.config file,
but I can't find this file in my netbrain CE. Please tell me how to enable this function.Thx.
Old 04-12-2018, 01:44 AM
Wengong Sun
Guest
Posts: n/a
Default Re: NetBrain SOAP API web services
Sorry for the inconvenience and it seems that CEv6.2 doesn't include the soap api web services. I will ask our document team to edit the online help. Can you please explain your issues in more details. I will check if there are any other workaround for them.
Reply
Bookmarks
Tags
Consultant Edition
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
