Netbrain
Go BackThe Net-BrainerNetBrain Product Curved lines between objects
Reply
Old 12-05-2018, 06:10 PM
gabrielshorn gabrielshorn is offline
Default Curved lines between objects
Probably a dumb question, but I can't find a way to make a link between two devices curved for the sake of cleaning up a diagram. I can do it once exported to Visio, obviously, but would love to make curved lines part of the dynamic map. I'm making L3 maps with L2 links between them instead of the L3-style lines that are "curveable." Thanks.
Old 12-06-2018, 01:06 AM
Administrator
Default Re: Curved lines between objects
Hi,
Sorry for dynamic map doesn't support curved links between two devices.
I have filed a feature request 81815 to our Product Management team. They will evaluate the request and decide how to proceed. We will keep you posted on the progress.
Old 12-07-2018, 04:53 PM
Thanks for your reply. That's what I had guessed. It would be nice. Another thing would be to be able to add layers to a map, and have those layers export as separate layers to Visio.
Old 12-13-2018, 09:21 PM
Administrator
Hi,
May I know what do you mean to be able to add layers to a map? Do you mean map layout? NetBrain IE7.1 supports to save a map layout as sample and then apply this layout template on a map. Please refer to the help info:
https://www.netbraintech.com/docs/ie...uto-layout.htm
Please kindly provide more details or example if I misunderstand, thank you.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
