Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Displaying host name
Reply
Old 04-23-2014, 12:15 PM
jsedlander jsedlander is offline
Default Displaying host name
In the L2 maps I've extened host off the switches. These host are displayed as IP addresses. Can NetBrain pull the DNS name and display the host name and IP address
Old 06-11-2014, 09:10 AM
admin admin is offline
Administrator
Default Re: Displaying host name
NetBrain does not resolve the DNS names of your end-systems/servers automatically. If you want to see the DNS names on the map, you can resolve them from One-IP Table.
Here are the instructions:
1) Open the One-IP Table from L2 Topology tab on the Ribbon Menu
2) Expand the LAN segment(s) for which you want to resolve the DNS names
3) Select the IPs (using Shift or Ctrl key) à right-click à Select Resolve DNS (Picture below)
NOTE: There is an option called “Resolve All DNS” on top of this table. That could take several minutes depending on the total number of entries in the table.
4) Add endsystems to the Workspace Pane. After resolving the DNS, you can select the endsystems in the One-IP Table, right-click these items and select the Add End Systems option. Then you drop and down the endsystems to the Q-Map, you can get the DNS names and IP info of the endsystems.
Reply
Bookmarks
Tags
Network Design, Network Discovery, One-Skill, one-skill-at-a-time, Set Up
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
