Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time How to enable dynamic routing accross Frame-relay network?
Reply
Old 07-16-2009, 04:51 AM
Chris Chris is offline
Default How to enable dynamic routing accross Frame-relay network?
Preview Qmap: "Frame-relay Basis.qmap"
According to the topology above, there are 2 virtual circuits between R3, R4 and R5. Configure Frame-Relay on a subinterface of each router so that dynamic routing functions properly across any two devices.
Old 07-16-2009, 04:54 AM
Default Knowledge Points
There are two types of sub-interface: point-to-point and multipoint.
  • Point-to-point sub-interface allows only 1 dlci configured via
    (config-if)#frame-relay interface-dlci DLCI-number
  • Multipoint sub-interfaces, first disable inverse ARP via
    (config-if)#no frame-relay no inverse-arp
Then use "(config-if)#frame-relay map ip 11.11.11.4 304" to map the next-hop with the DLCI. Add broadcast parameter behind this command to support the transmission of broadcast and multicast packets.
Reply
Bookmarks
Tags
CCNA, Network Design
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
