Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time How to avoid broadcasting traffic in a OSPF over Frame-relay network?
Reply
Old 07-16-2009, 05:32 AM
Chris Chris is offline
Default How to avoid broadcasting traffic in a OSPF over Frame-relay network?
Preview Qmap: "OSPF over Frame-relay.qmap"
According to the topology above, configure OSPF over Frame-Relay such that no broadcasting traffic required across Frame-Relay cloud.
Old 07-16-2009, 05:37 AM
Default Knowledge Points
  • If IP to DLCI mapping statement does not have the keyword "broadcast", OSPF neighbor relationship will not establish.
  • To get around, use startic neighbor command. Using neighbor X.X.X.X under OSPF process to send the hello packets via unicast.
  • To fix the mis-matched Hello Timers between point-to-point and multipoint interface, configure ip ospf network point-to-multipoint non-broadcast in R3's s0/0.1
Reply
Bookmarks
Tags
CCNA, CCNP, Network Design, OSPF, Routing
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
