Netbrain
Go BackThe Net-BrainerNetBrain Product How to set the management IP as a reachable IP address
Reply
Old 12-25-2012, 08:05 PM
Administrator
Default How to set the management IP as a reachable IP address
Problem: You may find some devices are unreachable in NetBrain but actually they can be accessed.
Root Cause: NetBrain pick up the first accessible IP address as management IP during discovery. If in the future, that IP/interface is shutdown, then, netBrain has no live access to that device.
Solution: For devices without any device settings, Tune live access will auto set the management based on interface type, starting from Loopback, then Ethernet/vlan/serial/&, as long as the 1st IP is accessible via ping/snmp.
Applicable to: All devices
Note: It will take time to run the tune live access for whole workspace. You can run it based on selected device group, or from the q-map during the troubleshooting, right click on the map > Tune live access, it will only tune the devices in the map, so you can quickly collect all data you needed during troubleshooting time.
Reply
Bookmarks
Tags
Consultant Edition, Operator Edition, Personal Edition
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
