Netbrain
Go BackThe Net-BrainerNetBrain Product Retrieve Routing Table with SNMP only Cisco
Reply
Old 05-06-2013, 05:27 AM
Doesterhuizen Doesterhuizen is offline
Default Retrieve Routing Table with SNMP only Cisco
Hi
Some of our devices are not managed by ourselves, hence we dont have login credentials for these devices.
How do I retrieve the routing table of these devices with SNMP only?
Thanks
Old 05-06-2013, 07:36 AM
Gerry Gerry is offline
Administrator
Default Re: Retrieve Routing Table with SNMP only Cisco
Quote:
Originally Posted by Doesterhuizen View Post
Hi
Thanks
Hi,
Go to Ribbon menu, switch to Workspace tab, click Vendor model drop down menu, select Device Driver Properties, double click Cisco Router(IOS switch) entry to open Device Driver Properties, switch to Route table tab, check the option: Build entire route table by SNMP. Then try to retrieve it via snmp, see screenshot below:
By default, you should be able to find path via snmp.
Hope it helps.
Gerry
Old 05-08-2013, 01:47 AM
Awesome it works!
Reply
Bookmarks
Tags
Network Design, Network Discovery, Routing, Snmp, Static Routing
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
