Netbrain
Go BackThe Net-BrainerNetBrain Product Site list updates
Reply
Old 08-28-2014, 02:45 PM
ap1436 ap1436 is offline
Default Site list updates
Can I export the site list to excel or comma deliminated, make changes to that list and than import the list? Along those same lines if I create a comma deliminated or excel spreadsheet with a lot of site updates and than import that list will it add to what I already have or over write what is currently there?
Thanks
Old 08-29-2014, 02:40 AM
Administrator
Default Re: Site list updates
Hi ap1436,
Thanks for posting.
NetBrain allows users to define a Site tree by importing a spreadsheet(Excel or CSV) which makes it easy to setup the Site definition procedure. Users can define a Site hierarchy by assigning a column header level. Please refer to the instructions in this link.
Also in OEv5.2 release, NetBrain now allow you to recreate Site hierarchy with the new spreadsheet. If you only want to merge the site, please leave this option unchecked.
[NetBrain]Case#00010874
Reply
Bookmarks
Tags
Network Design, Network Discovery, Site List
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
