Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time How do I link the customized info field to actual data
Reply
Old 11-12-2014, 01:51 PM
ap1436 ap1436 is offline
Default How do I link the customized info field to actual data
under properties, customized Information there are 3 default fields and ability to add fields but how do I link that to actual data pulled from a device?
Old 01-19-2016, 03:11 AM
Administrator
Default Re: How do I link the customized info field to actual data
Hi ap1436,
Thanks for using Netbrain Forum & Sorry for the late response.
For the 3 fields in the customized information at the properties, these options are designed for the Asset Report. You could only modify it manually by following steps below:
1. From the Asset Report window, click the Define Attribute button in the ribbon bar, the Attribute Settings window opens.
2. Select an attribute in the Customized Information and click the modify button. The Modify Attribute window opens. You can enter an alias and select whether to export this property to the report.
Hope this helps and please feel free to raise question when you got one.
Thanks.
Case#00034226
Reply
Bookmarks
Tags
Network Discovery, One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
