Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time cli procedure with single line output
Reply
Old 11-12-2014, 04:14 PM
ap1436 ap1436 is offline
Default cli procedure with single line output
I want to create a procedure for the results of the cisco command "sh snmp location". The output of this command is simply the location in the snmp field, for example:
router1#show snmp location
9216 S Major. Chicago, Il 60451
I want to capture the line "9216 S Major. Chicago, Il 60451" but can't figure out how to do that with what type of parser, keyword, paragraph, table or filter
some guidance would be great.
Thank you
Old 01-18-2016, 11:12 PM
Administrator
Default Re: cli procedure with single line output
The Paragraph Parser is the correct method to use in this case. Check our Qapp exchange website to learn more about how to write a Qapp and also to share your Qapp with others.
http://qapp.netbraintech.com/
Reply
Bookmarks
Tags
One-Skill, Procedure
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
