Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Automatic Asset Report
Reply
Old 03-08-2016, 12:10 PM
ceric ceric is offline
Default Automatic Asset Report
I've been instructed to retrieve a daily asset report (all devices) and email that excel file to my VP everyday. Is there a way to automatically retrieve the asset report and email it out every morning?
Old 03-08-2016, 08:36 PM
Administrator
Default Re: Automatic Asset Report
NetBrain currently doesn't support automatically generate/send the asset report but it is a feature request from our customers so we will be supporting this but we do not have any ETA yet.
Case#31644
Old 03-09-2016, 08:56 AM
Thank you for your reply.
Old 09-08-2017, 08:28 AM
Declanw Declanw is offline
Hi NetBrain Tech,
Has this feature been provided yet?
best regards
Declanw
Old 09-11-2017, 02:54 AM
Administrator
Quote:
Originally Posted by Declanw View Post
Hi NetBrain Tech,
best regards
Declanw
Hi Declan,
NetBrain currently doesn't support automatically generating/sending the asset report in version 6.2 or version 7.0, I will file a version 7.X feature request on your behalf to our Product Management team and follow up with them on this issue. I will keep you posted on the progress.
Case#67125
Old 08-07-2018, 03:32 PM
Jonathan Mulsman Jonathan Mulsman is offline
Has this feature been implemented yet?
As an alternative, the doc "What's new in NetBrain 7.1" mentions a new feature, a "Qapp Scheduler". Can this new feature be used to automatically run a report at a particular time, and either send the output by SMTP or save the output file to a local drive?
Old 08-08-2018, 03:19 AM
Administrator
Hi Jonathan,
I am very sorry to tell you that the feature is not planned.
In Netbrain V7.1, the "Qapp Scheduler" supports to schedul to export FRU report, Report Interface Error Counters, Stackable Switch Report and VSS report on a regular basis. But the export process still needs to be done manually.
Old 11-27-2018, 08:45 AM
Hi,
That sounds like it is never going to be provided.
Is that the case?
Regards,
Declan Watts,
BT plc
Old 12-03-2018, 04:45 AM
Jia.Xing Jia.Xing is offline
Hi,
Is that the case?
Regards,
Declan Watts,
BT plc
Hi Declan,
Qapp can now support to send "Error" and "Warning" alerts to email receivers automatically. In many use cases this is a great process.
However, I'm so sorry to tell you that sending CSV files to email receivers is still not supported yet. We'll file this as a feature request and let's hope it'll be supported eventually.
Thanks for understanding!
Case number: 00081680
Reply
Bookmarks
Tags
One-Skill, one-skill-at-a-time, Operator Edition
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
