Netbrain
Go BackThe Net-BrainerNetBrain Product Exciting new features in coming release v6.2-Runbook
Reply
Old 10-13-2016, 05:46 AM
Administrator
Default Exciting new features in coming release v6.2-Runbook
Runbook is a new way to integrate NetBrain features into a repeatable and documentable process.
Building a Runbook
Select blocks among the following options and split branch blocks based on your real needs. Only a single branch is displayed at one time.
Using a Runbook
o Search or browse existing Runbooks with preview.
o Click the play button to execute a Runbook. Each active block inside a Runbook also has a play button and can be run independently.
o Support to open recently used Runbooks on the current map from the map context menu.
Runbook Analysis (RBA)
o Completed blocks are marked with the count of runs. When alerts are generated, the icon will be displayed next to the result.
o Runbook Analysis is saved within the Qmap where it is running against. You can annotate more context and share the RBA with your colleagues for further collaboration.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
