Netbrain
Go BackThe Net-BrainerNetBrain Product Exciting new features in coming release v6.2-Qapp Improvements
Reply
Old 10-20-2016, 05:57 AM
Administrator
Default Exciting new features in coming release v6.2-Qapp Improvements
1. API Server is a new centralized module under the Qapp ribbon. You can define credentials for third-party API integration.
2. Qapp Qualification is newly introduced to filter devices during Qapp execution. You can define devices supported by a Qapp in the Qapp full editor so as to reduce the time to find applicable Qapps that can be run on the currently mapped devices.
3. The interface key is auto-populated in the Qapp Wizard. You can click Save & Run to run the Qapp immediately.
4. For a Qapp created via the Qapp Wizard, you can continue to edit it via the Qapp Wizard as long as it has not been edited in the Qapp full editor.
5. Add three built-in path-aware Qapps as sample Qapps and support to select more available attributes when using path as device input.
6. Re-organize the Run Result Pane to show more statistics about the Qapp output.
7. Qapp Debug Log is newly introduced to collect Qapp info, device info and failure reasons when a Qapp does not generate the expected results due to mismatched device type, wrong parser or unrecognized CLI command in a multi-vendor network environment. The Qapp debug log can be exported as a map file. You can share the map file with the Qapp author or others for further collaboration.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
