Netbrain
Go BackThe Net-BrainerNetBrain Product I am not able to activate the Qmap Reader using the license key that sent from your side.
Reply
Old 11-23-2016, 10:22 PM
gramat gramat is offline
Default I am not able to activate the Qmap Reader using the license key that sent from your side.
Keep getting “The Key is invalid” from the application. Even copy/paste has same results.
Old 11-23-2016, 11:26 PM
Eric Eric is offline
Default Re: I am not able to activate the Qmap Reader using the license key that sent from your side.
Quote:
To use the Qmap reader, you do not have to activate the license since this is a totally free tool.
You can ignore license activate window by clicking Later option, which will not hinder the functionality of the product. There is no expiration date even if you don’t activate the license.
Old 04-03-2018, 09:29 PM
jimmytootshoes jimmytootshoes is offline
I just downloaded Qmap Reader and had this same problem. The license key was emailed to me, but the software reports it as invalid.
There is no problem using the software. Just wanted to mention, there is still apparently a bug with the license aspect of it.
Old 04-04-2018, 08:06 AM
Administrator
Thank you for the notification! We'll check and modify that.
Reply
Bookmarks
Tags
Qmap Reader
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
