Netbrain
Go BackThe Net-BrainerNetBrain Product General Approach to Failed Pathing?
Reply
Old 12-06-2016, 01:56 PM
netbmed netbmed is offline
Default General Approach to Failed Pathing?
If I hop onto Router A and run a traceroute to Router B - it traverses several hops and finds its target. If I try to use the path tool in netbrain it falls apart after a single hop complaining "No matching entries found for destination IP (router B address) in Routing Table Path failed: No next hop IP and output interface found. What would be the best way to debug this type of path tool failure?
Old 12-07-2016, 01:03 AM
Administrator
Default Re: General Approach to Failed Pathing?
Quote:
Through the error message, I suspect that the device has live access issue.
Normally, you can find out some problems by looking at the Path log. After the A-B path calculating, click the curved path of this device to view the device log. The path log provides the detailed information and show the processing logic for each hop used in the path analysis profile. You can use the LEFT or RIGHT key on your keyboard to view the analysis log generated for the last/next hop.
By analyzing the path log, if you determine this is a live access problem. You can try to use the “Tune live access” function to debug live access issue first. Then calculate the A-B path again.
If the issue still exists, you can also save the current Qmap and sent it to [email protected] One of our engineer would like to help you as soon as possible.
Reply
Bookmarks
Tags
BGP, OSPF, Routing, Static Routing
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
