Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time How to discover a device that does not respond to ping?
Reply
Old 01-18-2017, 09:03 PM
Jake Jake is offline
Default How to discover a device that does not respond to ping?
Old 01-18-2017, 09:15 PM
Administrator
Default Re: How to discover a device that does not respond to ping?
There are two ways to add devices into workspace if it doesn't respond to PING:
1) Import their configuration file directly into Netbrain from Workspace > import configuration.
2) To enable “Tune Live Access” for your devices, you can disable the option where if ping fails then netbrain will not discover the device. Browse to “NetBrain” icon on the top left corner of workstation, choose “options”. Please check the attached file for your reference.
Old 01-15-2019, 04:16 PM
Dustin Dustin is offline
How do I achieve this same thing in version 7.1a?
Edit:
I've answered my own question.
Domain Management -> Operations -> Advanced Settings
Thank you,
Dustin
Reply
Bookmarks
Tags
One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
