Netbrain
Go BackThe Net-BrainerNetBrain Product Changing icons assigned to a device
Reply
Old 03-01-2017, 03:33 PM
ap1436 ap1436 is offline
Default Changing icons assigned to a device
under workspace vendor model i am allowed to change ICONs per device type however it only allows to use .emf files. Can Netbrain utilize icons similar to Visio stencils and if so how can import a .vss file into netbrain?
Old 03-02-2017, 08:36 PM
Administrator
Default Re: Changing icons assigned to a device
Hello,
Unfortunately, only the format of emf file is supported to change the icon with.
You have to convert the vss file into emf file, and import them to NetBrain to change the icon.
NetBrain Case#00059466
Reply
Bookmarks
Tags
icons, mapping
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
