Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Change Management feature not working as expected
Reply
Old 03-14-2017, 06:07 PM
aducey aducey is offline
Default Change Management feature not working as expected
It's timing out at the username prompt, won't execute. Any suggestions?
Thanks!
Old 03-15-2017, 05:07 AM
Administrator
Default Re: Change Management feature not working as expected
Hi,
If the auto login cannot pass through the username prompt part, you need to check if you had configured the Local Network Setting which to add local Telnet credentials for Smart Telnet and Change Management.
Noticed that we had a case created regarding this issue, and I had sent the details that need to be checked at your side via e-mail.
NetBrain Case#00059938
Reply
Bookmarks
Tags
Network Troubleshooting, One-Skill, one-skill-at-a-time
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
