Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Cannot select a shared workspace in my workstation
Reply
Old 07-07-2017, 12:26 AM
libingx006 libingx006 is offline
Default Cannot select a shared workspace in my workstation
See below login screen where I am unable to change the server address and workspace- Please let me know the cause of this problem. So that I can fix this problem for the user
Old 07-07-2017, 03:52 AM
Wengong Sun
Guest
Posts: n/a
Default Re: Cannot select a shared workspace in my workstation
Can you access your NetBrain Server from the PC on which your current workstation installed? If not, could you please fix the connection issue first and then try the followings to see if it can be resolved?
Reply
Bookmarks
Tags
One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
