Netbrain
Go BackThe Net-BrainerNetBrain Product Device links showed down during monitoring in IE7.0
Reply
Old 08-23-2017, 03:18 AM
Ellen1 Ellen1 is offline
Default Device links showed down during monitoring in IE7.0
Hi there, why the links of device showed down during monitoring? It's a core device and I'm pretty sure we have traffic on it.
Old 08-23-2017, 06:18 AM
Administrator
Default Re: Device links showed down during monitoring in IE7.0
Hi Ellen1, sorry to hear that.
Could you please drag and drop the problematic device to a map, then double click to open the “Properties” window, then switch to "interface" and check whether you can see the MIB index for corresponding interfaces.
If the MIB Index value is null, please first right click on the map to "Retrieve Live Data" with "Interface Information" checked. Please make sure you select "Auto update configuration file(all selected data) to Current Baseline"as well.
When the retrieve task completes successfully, please re-check whether you can see the MIB Index for the interfaces. If yes, please run monitoring again to verify.
If you still have issue with monitoring, please feel free to submit ticket to support@netbraintech.com, thanks.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
