Netbrain
Go BackThe Net-BrainerNetBrain Product Fail to log in NetBrain due to Database issue
Reply
Old 09-29-2017, 01:55 AM
libingx006 libingx006 is offline
Default Fail to log in NetBrain due to Database issue
I cannot login NetBrain and the webpage pops up an error of "The server encountered an internal error and was unable to complete your request. Please try again"
after I click the OK, there is another error "Fail to log in due to database issue"
Old 09-29-2017, 03:36 AM
Wengong Sun
Guest
Posts: n/a
Default Re: Fail to log in NetBrain due to Database issue
Could you please do the followings to see if this issue can be resolved?
1. Test if your MongoDB is working well or not:
mongo --host $your_mongodb_server_ip:27017 -u $your_mongodb_username -p $your_mongodb_password --authenticationDatabase admin
Note:
1. Both Windows MongoDB(Just for POC) and Linux MongoDB can use the same command to connect to MongoDB.
2. $your_mongodb_server_ip is the serverip
3. $your_mongodb_username is the User Name
4. $your_mongodb_password is the Password
On Windows
On Linux
2. Check IIS settings of the server which hosts NetBrain Web API Server
3. Check the FIPS settings of the server which hosts NetBrain Web API Server
The value is set as 1 means that you have enabled FIPS on your server. NetBrain cannot support this feature in our current release.
Could you please double check if you are using the FIPS on your server. If not, please set the above value as 0.
If yes, NetBrain cannot support this feature in our current release. Could you please set it as 0 as a workaround? I will forward this case as a feature request to our PM team for reviewing.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
