Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Tab editing
Reply
Old 09-29-2017, 10:48 AM
frodriguez frodriguez is offline
Default Tab editing
Hello,
I have EE6.2, and my workstation's Home tab does not display the "traffic path" option. Is the Home tab editable so that I can add or remove features? And if true, how do I add the option for "traffic path"?
Thanks,
FR
Old 09-30-2017, 01:26 AM
Miranda Miranda is offline
Default Re: Tab editing
Hi Frodriguez,
I am Miranda from Netbrain support team. Thank you for your question.
The “Modules” in the Home Tab cannot be modified at the workstation side, it seems that you don't have enough authority to be able to use this function, you can contact your administrator to raise your user role permissions.
Please ask your administrator login to Customer License Server, go to User Accounts, and change your account role.
Here is the online help you can refer:
https://www.netbraintech.com/ftp/EE6...ging_roles.htm
Thanks!
Reply
Bookmarks
Tags
One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
