Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Visio version support
Reply
Old 10-16-2017, 05:17 AM
gramat gramat is offline
Default Visio version support
What versions of Visio are supported for Integrated Edition 7? I have Visio 2010 and it does not working.​
Old 10-16-2017, 06:43 AM
Administrator
Default Re: Visio version support
IE7.0 only supports to export Visio file with extension name vsdx, so Visio 2013 and Visio 2016 are supported for IE7.*
You cannot open a .vsdx file in Microsoft Visio 2010 until you install a Visio Compatibility Pack*
​Please refer to*https://support.microsoft.com/en-us/help/2844302/you-cannot-open--vsdx-or--vsdm-files-in-visio-2010
Old 04-09-2018, 05:27 AM
christoph.neulinger christoph.neulinger is offline
I have visio Viewer 2013 installed but it dose not open the document.
Should it work with the Viewer.
Old 04-10-2018, 04:59 AM
libingx006 libingx006 is offline
Visio Viewer is not supported in v7.0. Please file a feature request to Netbrain support team if there is a need.
Old 04-10-2018, 05:01 AM
Visio Viewer is not supported in Netbrain v7.0. Please file a feature request to Netbrain support team if there is a need.
Reply
Bookmarks
Tags
One-Skill, one-skill-at-a-time
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
