Netbrain
Go BackThe Net-BrainerNetBrain Product Netbrain 7 Discovery over LAN to LAN Tunnels Failing
Reply
Old 02-09-2018, 01:41 AM
netbmed netbmed is offline
Default Netbrain 7 Discovery over LAN to LAN Tunnels Failing
I ran discovery and in the main data center it finds all my PAN firewalls. However one of these PANs has several IP Sec lan to lan tunnels associated with it. And on the other side of those tunnels are the LANs of remote sites. None of those tunnels or remote sites are discovered. If I click on the + sign to stitch things together it sees the tunnel interfaces but has no awareness of the far end. Is this a limitation of NetBrain or is there some extra step that I need to make this work?
Old 02-11-2018, 04:21 AM
Administrator
Default Re: Netbrain 7 Discovery over LAN to LAN Tunnels Failing
Quote:
Hi Michael,
I think my collegue has answered your question via Email, i also attached the solution for reference.
Reply
Bookmarks
Tags
Firewall, Network Discovery
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
