Netbrain
Go BackThe Net-BrainerNetBrain Product NetBrain IE7.0 Qapp API Documentation?
Reply
Old 04-23-2018, 05:48 PM
jimmytootshoes jimmytootshoes is offline
Default NetBrain IE7.0 Qapp API Documentation?
Is there documentation for how to use the built-in Qapp APIs inside of NetBrain IE7?
The on-line help documentation is pretty sparse. It lists the built-in APIs, but doesn't give any examples of use, and doesn't detail supported syntax/usage.
Documentation for a few simple examples would be very helpful. For example, how to use NoteType to AddMessage to just say "Hello World!".
Old 05-02-2018, 04:24 PM
Default Re: NetBrain IE7.0 Qapp API Documentation?
Attached is a sample image I was sent from support. Shows how to use DrawDeviceNote to make a simple "hello world" message.
To use it you can create a Script type of Output from a Table inside the canvas and enter this:
Quote:
DrawDeviceNote($this,"This is note for Test", "Hello World", NoteType.Append)
Old 05-22-2018, 06:25 AM
Default How to use a string and variable in single message note
By default DrawDeviceNote only accepts one value for 'content'. Either a single variable, or a single quoted string.
If you want to use a single message (single line) that includes both a string and a variable, you can concatenate them before you call the function to draw the note.
For example, to draw a note that includes the message of the device name but preface it with text saying "Device Name: " you can use this script:
Code:
notetxt = "Device Name: " + $this
DrawDeviceNote($this, "This is note title", notetxt, NoteType.Append)
Reply
Bookmarks
Tags
api, python, qapp
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
