Netbrain
Go BackThe Net-BrainerNetBrain Product Debug Jumpbox
Reply
Old 07-13-2018, 11:01 AM
cramos cramos is offline
Default Debug Jumpbox
Does anyone know how to enable application debugging in Netbrain Workstation? I need to use a jumpbox (ubuntu) to access my network devices. When testing the jumpbox settings I get the below results. I verified that I can SSH from the Netbrain server to the jumpbox without issue. I also checked the syslog on the jumpbox and see no login attempts. I'm thinking this may be related to the way the shell is setup on the jumpbox. It drops you onto a blank line when you login.
SSH to [x.x.x.x] via local
SSH to [x.x.x.x] successfully via local
Prepare disconnecting to because of timeout(30 seconds) , Return from Device:[]
SSH to [x.x.x.x] Disconnected
---Jumpbox is tested unsuccessfully via Local---
Thank you in advance!
Old 07-16-2018, 01:13 AM
Administrator
Default Re: Debug Jumpbox
Hello,
Since the log shows that:
It seems that NetBrain could not recognize some prompt of the Jumpbox. We need more information such as the screenshoot of your jumpbox. What should the user input after the blank line appear? Could you please send an email to support@netbraintech.com? So a ticket will be created and we can help you better.
Reply
Bookmarks
Tags
Network Discovery
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
