Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Discovery behavior problem
Reply
Old 07-31-2018, 03:21 PM
ayoluca ayoluca is offline
Default Discovery behavior problem
Hi, I was wondering if Im missing something on the Netbrain settings, Im running version 7.0 and we are in the process of adding the devices,
however, from the netbrain server itself, Im able to ssh the network device, I can even manage from there, meaning that the ssh is allowed,
However, on the netbrain web app, whenever I go to discovery tab, I only get that SNMP is succeeded but not SSH
below the output, and just for the safety, I just marked the IPs with X.X.X.X, but you can see the rest of the output
Ping [X.X.X.X] via Proxy Server(X.X.X.X); Succeeded
Send RO = [X.X.X.X][version:v2c] to [X.X.X.X] via Proxy Server(X.X.X.X); Succeeded
Retrieving [X.X.X.X]'s Hostname ,Vendor and Model via Proxy Server(X.X.X.X); Succeeded
SSH to device X.X.X.X via Proxy Server(X.X.X.X)
SSH to device X.X.X.X disconnected.
Skip the step of retrieving config file via SNMP because CLI config already exists.
ASA running single mode
Discovery of X.X.X.X complete
Im trying to discover the ASA on the admin, since this is a multiple context.
Anyone has had the issue? how can I fix it?
I even tested the telnet command from the server and clearly the port is open,
I even tested the "Shared Device Settings" options to play with the credentials and it failed,
Live Access From Proxy Server(X.X.X.X):
Connection with Proxy Server(X.X.X.X): Succeeded
Ping: Succeeded
SNMP: Succeeded
Telnet/SSH: Failed
Your help is much appreciated please,
thanks
Old 08-01-2018, 01:31 AM
Administrator
Default Re: Discovery behavior problem
Please RDP to the proxy server, press win +R to open the Run window, enter “services.msc” to open the Services window, restart the "Netbrain Proxy Service of IE" service if you are in v7.0b1, or the "Netbrain Proxy Service" if you are in v7.0b.
Then try to rediscover this ASA, if the issue still stands, please file a ticket to NetBrain support team(support@netbraintech.com), this may need further analysis.
Thank you!
Reply
Bookmarks
Tags
One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
